Sponsored by: Kumho
front brake cailpers
Old Dec 31, 2003 | 02:23 PM
rustydog628's Avatar
rustydog628
HELP.
Just got finished replacing the front bearings on my 1986 f150 4x4.
Put new pads on but problem is when I went to bleed the brakes i could not get the bleeder valves to open on the front calipers on both sides .
My only thought was to take the calipers of and use a impact on them very carefully. I cant get a ratchet on them while the are on the truck as there is not enough room.
Any other thoughts ?
Old Dec 31, 2003 | 04:22 PM
StrangeRanger's Avatar
StrangeRanger
I wouldn't use an impact driver, too great a chance of breaking the bleeder off. Use a good penetrant to loosen them up first and break them loose with a 6-point, not a 12-point, socket.
Old Dec 31, 2003 | 04:28 PM
stepman's Avatar
stepman
I would go for the vice grips. Usually that will be enouh to do it. Can be done on the truck too.
Old Dec 31, 2003 | 05:51 PM
natewoz's Avatar
natewoz
Heat the caliper around the bleeder. It doesn't take much. Then use your bleeder screw wrench to crack the screw open. Watch out that you stay clear of the hoses with the torch.
Old Jan 2, 2004 | 11:34 PM
03f150man's Avatar
03f150man
use a penetrant like pb-blaster to free up the brake bleeders. Soak it good and wait ten minutes. good luck.
