30 amp fuses on engine
Old Dec 31, 2003 | 01:40 PM
boogerbutt's Avatar
boogerbutt
Question 30 amp fuses on engine
While replacing the Glow Plug Relay there was a arch from a washer which blew a 30 amp fuse located in the engine compartment fuse box. My friend took out another 30amp fuse from the same box and we promptly blew that as well. The truck runs fine without these two but NEED to know WHAT they are for and WHERE the little diagram is that explains the purpose for each of the fuses in this box.
Old Dec 31, 2003 | 03:13 PM
Quadzilla's Avatar
Quadzilla
I don't know the model year of your truck, but my '95 has a schematic molded into the fuse box cover. It doesn't tell you exactly what the fuse is for, but tells you what size fuse is for each slot. If you can tell us which fuse is blowing, for example the third from the bottom in the left row, we might be able to figure it out from an owner's manual.
Old Jan 1, 2004 | 05:53 PM
cangim's Avatar
cangim
My 99 has a molded schematic as well, the manual should tell you what fuse it is for, if you still have it, it not some one here probably does.
Redonkulous BOB
26
Nov 28, 2011 02:07 PM
benthere
Dec 15, 2010 09:37 AM
wsps1990
Nov 30, 2010 01:36 AM
tundraathome
Electrical Systems/Wiring
Sep 17, 2010 12:10 PM
D.R.800X2
15
Nov 4, 2008 10:01 PM
