New transfer case?
Old Dec 31, 2003 | 12:39 AM
Skagit's Avatar
Skagit
New transfer case?
I have an 81 bronco with a 351m, c-6, and np 208 tranfer case. I have two problems with the t-case, first the seal leaks around the yoke, even the new one, possible driveline problem?, second there is a small crack on it, it is not leaking but I dont remember seeing it a couple of months ago. So should i get a new t-case? Another 208 or is there anything better that will bolt up? Any tips on what to look for? Thanks in advance.
Old Dec 31, 2003 | 04:12 PM
redranger1's Avatar
redranger1
so you replaced the yoke seal and it still leaks? did you look to see if maybe the yoke isnt work excessively er pits that are allowing it to leak? about the crack, are you certain its a crack? i know the 208 i have has spots on it that look like crack but really arent. get ys some sand papaer and work a lil spot and see if it disappears. but untill it starts to leak i wouldnt worry bout it.
