HELP stranded
Old Dec 30, 2003 | 01:53 PM
speedwheeler's Avatar
speedwheeler
Angry HELP stranded
1984 f-150 i6 carbed
my 84 left me stranded today i had just put gas in it and i was pulling away from a stop light i hit third gear and it coughed spit and then died i pulled over and cranked it over and it coughed now there is nothing happeningi looked under the hood but found nothing visually wrong i have a "custom air filter setup its a proto type home built and i blocked off the egr by switching the vacume line around i havent had a chance to tinker with it yet i was wondering if any one had this happen to the and what cured it
Old Dec 30, 2003 | 03:20 PM
speedwheeler
my dad who i bought the truck from said it might be the computer im going to pull it home so i can tinker any suggestions
Old Dec 30, 2003 | 06:16 PM
Slade901's Avatar
Slade901
Blocking off the EGR is really a big NO NO because the computer still includes the EGR from its computational value and for air/fuel mixture.
Usually the Eprom inside the computer needs to be modified so it will disable and not monitor the EGR if you want to bypass the EGR.
Get a starting fluid and squirt a few in the carb opening and start the car and see if it starts and continue squirting to make sure that the engine would stay running until you stop feeding the starting fluid. If that is the case then you might have fuel related problem.
Fuel pressure gauge would narrow down the fuel problem.
Get a spark tester to see if you are getting consistent sparks from the ignition coil, etc..
Old Dec 30, 2003 | 09:41 PM
ck1404's Avatar
ck1404
I have had a vacuum leak before that would cause the fuel injectors to "flood" and subsequently lock-up which resulted in the no-crank situation. Holding the pedal to the floor would temporarily erase the flooded injector problem and the truck would start and run fine for a while. But, then, I thought 1985 was the first year for EFI, in which case this obviously does not apply?
Old Dec 30, 2003 | 09:45 PM
CrazyFordMan's Avatar
CrazyFordMan
84 computer????
Old Jan 2, 2004 | 09:38 PM
speedwheeler
its not a fuel prob its ignition and today i replaced the plugs plug wires the coil and the i c m
Old Oct 12, 2005 | 03:40 PM
speedwheeler
it was the distrubuter gear i sheared the pin
Old Oct 13, 2005 | 07:20 AM
Sycostang67's Avatar
Sycostang67
Been there, no fun, what caused it to shear, my oil pump seized on me and caused the roll pin in my dizzy gear to shear.
Old Oct 13, 2005 | 02:04 PM
speedwheeler
i dont know cuz it ran fine after that
