600 miles and counting
I changed the oil at 520 miles yesterday adding 6 qts of Motorcraft 5W20 and an FL400s filter. I noticed that the dip stick indicated I was 1/2 qt low, but I remembered that it looked about the same with the factory fill, so Im going to leave it there. All my manuals say 6 qts.
I also added some fog/daytime lights since my US truck didn't come with them. Found a nice spot below the bumper with two little tabs that worked nice for some small lights. Found an interesting way to power them. There is a circuit breaker box on the drivers wheel well under the hood. There is a blank spot for a trailer battery charging relay in the box that is hot when the engine is running. I wired a relay I had laying around, to the hot plugs and wha-la, running lights that only come on when the engine is running, and I can use my accessroy key position without turning them on too.
Final note, I have to say the 3.55 Posi-traction works great, running 30 PSI in the rear 255x70x16's. I went out today confident that my engine had enough miles on the clock to do some power testing. It was raining and the roads were soaked. I came to a stop, and then stomped it down and she sure sounded nice, but the back end hooked up with both wheel and I roared up a hill. Tried it again after going through about 10 feet of puddle and same result, I was doing 60mph in no time with no wheel slip. I hope the clutch packs are easy to replace, I have a feeling I'll be using them up.
