Sponsored by: Real Truck
No Muffler?
Old Dec 29, 2003 | 05:33 PM
webmook's Avatar
webmook
No Muffler?
Hello fellas,
I am thinking about running no muffler but keeping the cat on. 99 F350 V10 gas cat bakc split.
Any experiences, feedback, suggestions.....
Thanks in advance.
Old Dec 29, 2003 | 06:52 PM
99f350sd's Avatar
99f350sd
Sould be fine you might lose some low end power.RRRRRMMMMM
Old Dec 29, 2003 | 07:34 PM
ke6jcf's Avatar
ke6jcf
That's what's on my '99 runs great and sounds great.
Old Dec 29, 2003 | 07:52 PM
abendx's Avatar
abendx
ke6jcf... how much power would you say you lost..... ?
Old Dec 29, 2003 | 08:26 PM
RR 11's Avatar
RR 11
I ran my (96) old 150 that way for two years sound was great and I did nit notice any loss of power. I had planed to do this to my F250 when the 36,000 mile point has pased.
Old Dec 29, 2003 | 08:55 PM
Bennie C.'s Avatar
Bennie C.
On my previous 01 V10 Excursion I had a K&N filter and a straight thru MagnaFlow and gained .2-.4 MPG on the freeway. What surprised me the most was that it had a better acceleration which I was not really expecting since I was really after better gas mileage. .2-.4 mpg increase did not really justify the cost on the muffler and installation but it sure did put a smile on my face. As for the sound, you can barely tell even when you're sitting in the back and that was with the 14" muffler. If you wanna delete the muffler I'd say go for it. V10 does not rumble like the V8s does and if your not happy with the sound then you can always add a straight thru muffler.
Old Dec 30, 2003 | 09:16 PM
frederic nelson's Avatar
frederic nelson
Ihave a v10 without a muffler ,, sounds good at an idle and low RPM's ,, but when you stand on it barks LOUD ,, on the interstate it is louder but I can live with it fine ... PS some of my coworkers hate it when I jump on it leaving work because of the different sound a v10 makes ( winnies like a cotch rocket , will rattle the windows and turn heads ) Fred
Old Dec 30, 2003 | 10:13 PM
abendx's Avatar
abendx
fred.... have a sound bite or care to make one for us????
Old Dec 31, 2003 | 06:40 AM
ke6jcf's Avatar
ke6jcf
If anything it seems to have picked up some power in the bottom end. Could be it just sounds like it! All in all it is an improvement not a loss. I should also note that it seems to run smoother than it used to. These could be attributed to a bad muffler that was removed, it did rattle.
