overhead console, tripometer, mpg failure
Old Dec 29, 2003 | 04:56 PM
jegenrieder's Avatar
jegenrieder
Unhappy overhead console, tripometer, mpg failure
2000 F350 TD Lariat Crew
I've searched other forums without luck, except to learn that problems with the overhead console LED readout is often related to the dimmer switch. My dimmer seems to function fine.
1. Has anyone found a fix?
2. Has anyone pulled the LED unit out - how did you remove the plastic cover?
3. Does anyone know which fuse may control this (at my cabin without my manual)?
4. Any other ideas?
