Sponsored by: Auxito
CB radio location
Old Dec 28, 2003 | 09:58 PM
Bunggo's Avatar
Bunggo
Question CB radio location
Where is the best place to install a CB radio in a 2003 F150 SuperCab 4x4? I have captain's chairs, so my center counsel is huge and I was thinking about bolting it to the front of that. I'm basically looking for a semi-easy solution.
Bunggo
Old Dec 29, 2003 | 11:21 AM
F2504x4's Avatar
F2504x4
in my 95 & 97, i found the best plasc was mounting the cb on the roof, if you dont have a overhead console, what i did was remove the visors and clip that holds them, i took two pieces of metal,about 6inches long, 1/2 inch wide , predrill holes for the cb mounting braket,in the metal pieces the size of screws, get two clips,(the type that holds sheet metal together)to run the screws thru, now for the funpart you can slip your hand in the roof panel, by the wind sheild,you will have a tight fit but you find the roof gives a little, slip the metal pieces in, hold in place then attach the cb bracket to the metal pieces,this spreads the weight across, the card board roof,next run your wire along the top then down tthru the trim,to the dash, theres a gap there along the dash ,run it to the fuse box, done right you wont see anywires showing, reinstall the visors, now put cb in place,be sure to put a inline fuse at both ends,its a great location, the speaker points down and is close enough to hear without crankin it, ive gone off road and driven some rough detroit roads, it stayed in place plus some one cant eaily see it, and its out of the way,oh run the ant. wire the same way but down thru floor, there's a rubberplug somewhere to run it out side, hope this helps, im using a uniden pc76xlw with weather alert great radio,peaked&tuned, lets you know when to avoid tornadoes,bad storms :-staun
Old Dec 29, 2003 | 02:37 PM
lm1d's Avatar
lm1d
Uh....
I'm Eastbound and down, rolling up and trucking.....
Put the petal to the metal, I'm 10-10 on the side......
Gawd...
Old Dec 29, 2003 | 02:56 PM
F2504x4's Avatar
F2504x4
(CB)where are the bears,(cops) mile marker xxxsouthbound side, northbound look good goin that away. 10-4. (nonCBer) with raderdector, beep. beep. ect.... real? false signal? oops their he is ......oh no he got me..... (CB) southbound whys traffic stopped,.??nrthbound,bad accident mile marker xxxx you can bypass it by taking exit xx at mile marker xx, or northbound just north of xxxcity the roads get real slick (icey)at mile marker xxx ,southbound you got a brake check at milemarkerxxbrakecheck=traffic slowing real fast,be careful). (nonCB) honey whys traffic stopped, ah i dont know, daddy i gotta to the bathroom!(sitting & not movin,& not knowing) also lots of dumb conversation,with scary truckers also if you are only one can shy of a 6pack your radio has weatheralert onit
Old Dec 29, 2003 | 03:17 PM
F2504x4's Avatar
F2504x4
CB's free communication, info, road conditions an traffic updates, no license fees, great when travelin in groups, always someone to chat with when drivin alone, don t knock what you dont have or use, i travel 40+ ayear, it saves me tons $$$ & time, its a great tool and more accrate than rader,laser detectors ever have been,and for directions , jus about every store,factory and buisness have a trucker delivering to it, CB's arnt jess fer hicks
Old Dec 30, 2003 | 09:58 PM
F2504x4's Avatar
F2504x4
im1d
Old Dec 30, 2003 | 10:53 PM
LxMan1's Avatar
LxMan1
that's what 530 on your Am dial is for, local traffic info.
I thought everybody had cellphones or Nextel 2 way now.
I got Rid of my CB's along with my Platform shoes and bell bottoms.
I never got any useful info on them, and these days' 36 of the 40 channels are spanish and I can't understand a D%&$ thing that they say!!
Old Dec 30, 2003 | 11:04 PM
F2504x4's Avatar
F2504x4
i dont know how often you used yours, but ive used mine for 8yrs now wont travel without it, dont have to dial, while driving, spend minutes, plus roaming fees for directions?,bell bottoms back in stlye now and i never needed platfrom shoes anyways, am? what that? sat radio way to go now. i drive oh.ky mi,wv,ind. on a regularly. channel 19 still uses english. spanish to be second national lang. pretty soon p.s do you still think all the radio station use real planes still? oh well...this is capt'n mad jack cruising the skyways with air vision signin off for whio am radio1410
Old Jan 1, 2004 | 08:35 PM
Bunggo's Avatar
Bunggo
Believe it or not, there is no "official" language of the United States. It just so happens that English is the number one language spoken, and Spanish is the second most spoken language... Nonetheless, there is only one post answering my question on where to put a CB radio. I don't care if you stopped using one when you got rid of your bell-bottoms (which is funny because bell-bottoms are 'in' again). So, where is the best place to mount the antenna? I think I know where I want to put the radio, but where should I put the antenna?
Old Jan 1, 2004 | 09:19 PM
RaytownF150's Avatar
RaytownF150
Are most of the members here [deleted]? I just joined this group, and I will be more than happy to leave if this is the general mentallity of this group. Some of you folk are one step up the food chain from bananas.
Old Jan 1, 2004 | 10:43 PM
F2504x4's Avatar
F2504x4
as to where to put the radio ant. they say the highest part of the vehical for best reception, but put it where you think is best, asto what raytown said ,look if you cant take alittle ribbin, weell.........hmmmm .....i cant think of a good comeback right now oh wait its done in fun.... ........ but if yoy decide to stay glad to haveyouhere. but as to me i take no offence and dont mean to give any. i put my ant under my chin and open mouth so it will transmit farther it really works , i learned about in another thread that i read here
Old Jan 1, 2004 | 10:59 PM
F2504x4's Avatar
F2504x4
bunggo let us know how it turns out and what you did, i use a magnet mount and put it in the center of the roof, holds up to 90+mph 36 inch tall,
Old Jan 1, 2004 | 11:29 PM
LxMan1's Avatar
LxMan1
generally the magnetic roof mounts seem to get the best reception. If you put a soft piece of cloth between the magnet and the cab, it shouldn't mess up the paint.
As to the radio itself, it is all in personal preference. You say that you have the bucket seats with the stand alone console? The front of it between the console and the dash would probably be the best place. You should be able to hide the wires there and it shouldn't be in the way.
And yes, I know that bell-bottoms are coming back. It's just ashame that they we ever invented in the first place. I guess it was to hide ugly shoes!!
And as for you RaytownF150, chill buddy. This is a friendly site. We do kid each other from time to time, but we also give the best info on the net. There are alot of good people on here and I have yet to see a question go unanswered.
There are a lot of actual Ford service techs and service advisors on this site along with the thousands of us who have real world experience with all sorts of problems, so if you have a question or problem, 99 times out of 100 you will get the info you need here. Granted, it may take a day or two sometimes because not everybody is on here at the same time.
Anyway, here is a big welcome from all of us at FTE We hope that you stick around and enjoy the site.
Jimmy
Old Jan 1, 2004 | 11:39 PM
dyarumian's Avatar
dyarumian
i have a 3' magnet mount arial works great on the road but it will fall down when it hits anything (branches when offroading, or the roof or the parking garage for you city folk) but the good thing is that you can just pull it off whenever you need to. As for the actual radio i put it right under the ash tray above the center hump (on my bronco) and mounted the mic right by my steering wheel
Old Jan 2, 2004 | 08:21 AM
banjopicker66's Avatar
banjopicker66
I don't have the console, but the 60/40 double bench in the front.
I put mine just below the double power outlets, using small interior panel screws to hold the bracket to the plastic. I fastened the mic clip to the bottom of the radio, and ran the wires under the carpet, behind the door molding and out the rear (extended cab) window.
The antenna is a small magnetic rubber ducky type.
Works just fine for the short ranges I need on the road.
