1991 5L engine problem - HELP!
Old Dec 28, 2003 | 05:45 PM
edterry's Avatar
edterry
I have a '91 5L which has melted #2 and #8 pistons. How can this happen, and how can I prevent it from happening again when I get another engine from the wreckers?
Can I swap this motor with an inline 6? What kind of problems can I expect if I do? (same electronics?)
thanks
Ed
Old Dec 28, 2003 | 06:12 PM
c_rossman's Avatar
c_rossman
Wow! You must have done some high rpm cruizing to burn up pistons in a 4stroke. Usually a valve will burn before a piston and there would be alot of pinging going on. I would say you have a lean condition. Maybe two bad injectors or bad fuel regulator.
