engine bogs when air cleaner on
Old Dec 28, 2003 | 12:43 PM
raceman77's Avatar
raceman77
l just bought this 85 F350,it has a 460 with reman heads and t-chain just done.l just put a factory reman carb on it because the other carb was for a manual trans...now it idles well and it runs okay with the new carb but if l install the air filter assy.it bogs really bad.lt seems to need more air,less fuel.lt did this with the other carb too.l was told the carb was bench tested at the carb facility and floats set etc and that l`d only have to set the idle...any ideas? any help appreciated
Old Dec 28, 2003 | 01:29 PM
DanMartin's Avatar
DanMartin
raceman77,
Make sure the bottom of the air cleaner isn't pushing on the choke linkage, causing it to close off partially.
Some carbs require a dimple in the air cleaner bottom or a spacer to prevent this from happening. Something to look in to....
Dan Martin
86 F350
Old Dec 28, 2003 | 03:52 PM
Big Red's Avatar
Big Red
I agree with DanMartin... my carb has a spacer ring on the top of it that the air cleaner sits on.
Old Dec 28, 2003 | 05:28 PM
raceman77's Avatar
raceman77
thanks guys,l checked that first and all is well there...l set the timing at idle with a vacuum guage and re-routed the dist.advance to the proper port- big improvement but still not what it should be.l`ll set the timing with a light next but it seems like l`m still getting too much fuel.l`ve heard about power valve replacements for high altitude(l`m at 7000 ft) and l may check that too...
Old Dec 28, 2003 | 05:55 PM
DanMartin's Avatar
DanMartin
raceman77,
Did you check/set the float level? That could cause a rich condition too.
Dan
Old Dec 28, 2003 | 06:33 PM
raceman77's Avatar
raceman77
floats are set...
Old Dec 28, 2003 | 07:10 PM
Franklin2's Avatar
Franklin2
"l`ve heard about power valve replacements for high altitude(l`m at 7000 ft"
This is certainly not helping. Definitely less atmospheric pressure at 7000 ft. I would contact Ford and see if they have recommended jets and carb calibrations for high altitude.
DavidMc70
Aug 11, 2013 11:32 PM
amosmoses
Aug 15, 2012 05:38 PM
dialogueonlife1
May 9, 2007 03:56 AM
72tank
Jun 21, 2006 11:59 AM
raceman77
Jan 2, 2004 12:25 AM
