Oil & Lubrication
after the new engine breaks in, does it
Old Dec 28, 2003 | 08:15 AM
Greg 79 f150's Avatar
Greg 79 f150
really matter what top grade oil one uses (as long as it is in user manual specs) or should you stay with what ever brand the dealer put in it as new ? I dont know how a person would find out what the dealer put in it as new anyway,
Old Dec 28, 2003 | 11:49 AM
78fordman's Avatar
78fordman
I would stick with valvoline or mobil, havoline also makes a good oil. Stay with the same brand of oil, or excess of engine wear can occur. Do not use a fram penzzoil or quakerstate oil filter, and you should be good to go. They probably put in motorcraft oil and a motorcraft oil filter. Stay away from pennzoil.
Old Dec 28, 2003 | 06:21 PM
Beast12's Avatar
Beast12
I second that!
-Matt
Old Dec 28, 2003 | 07:41 PM
BlueRanger94's Avatar
BlueRanger94
What matters is that you follow the recommendations in the owner’s manual. Use whatever you like as long as it’s the correct grade and API certified. I think the idea of using one oil for an engines life is just some old garage tail. We all have our preferred oils for one resin or another, maybe even color of the bottle.
Pennzoil is good oil just like all of the other major brands. The oils I would stay away from are the ones with amazing claims.
Filters do matter and I think the one thing we can all agree on is that fram is probably not good enough.
Old Dec 28, 2003 | 11:55 PM
Jeff726's Avatar
Jeff726
What do you say about constant switching of oil brands?
Old Dec 29, 2003 | 09:34 AM
78fordman's Avatar
78fordman
Engine wear occurs, and it wears different to each different type of oil, mainly differences on where is was pumped. Then you switch brands, it starts weaing different, chemical reactions and so on, easier to just stick with one brand.
BlueRanger94
I don’t see any problems with constant switching of brands. I use whatever name brand oil is on sale. The motor has no concept of brand. All regular oils are compatible with the residue of the previous oil.
Old Dec 29, 2003 | 10:16 AM
doyall's Avatar
doyall
Originally posted by 78fordman
... Stay with the same brand of oil, or excess of engine wear can occur. ... Stay away from pennzoil.
I would be interested in knowing what facts are being used to support these assertions.
Old Dec 29, 2003 | 11:12 AM
78fordman's Avatar
78fordman
I was always told that when you change brands, you take the chance of burning out your oil rings. That wear charactaristics in each oil is different, thats just what i was told.
Old Dec 29, 2003 | 11:35 AM
BlueRanger94
Maybe that was some type of marketing line to keep users of brand X oil buying brand X oil.
Old Jan 2, 2004 | 09:07 AM
peppy's Avatar
peppy
http://minimopar.knizefamily.net/oil...y.html#warning
Whoops, thats the link to start with. This sight provided me with answers to questions I never thought to ask.
Old Jan 3, 2004 | 05:35 AM
BlueOvalFitter's Avatar
BlueOvalFitter
I prefer Chevron Supreme. I have used Castrol,Havoline,Motorcraft,and Valvoline in my 97 too.But always have used Motorcraft oil filters!
Old Jan 30, 2004 | 08:57 PM
therion's Avatar
therion
I recommend you run dino for the first 500-1000 miles and then switch to synthetic to make sure it gets broken in. Synthetic will prolong the break-in period. Redline, Amsoil, Mobil, are all good oils, which one you choose depends on the type of service and how much money you are willing to spend - also how long you intend on keeping your vehicle.
