1978 - 1996 Big Bronco
odometer/towing
Old Dec 27, 2003 | 03:57 PM
greg9942's Avatar
greg9942
odometer/towing
I have a 93 bronco and I was wondering if I towed this behind a RV and took the drive shafts out would it still rack up the miles on the odometer?? Also if you could tell me where its located.
Old Dec 27, 2003 | 05:45 PM
brannma's Avatar
brannma
I don't think it will eveen if you pull the shafts: Its an electric odometer, so if its off, it should not accumulate. If it is still racking up miles while off, you could pull the battery and that would for sure keep it from accumulating. Be easier than shafts to install when you needed the truck for a lift.
