I hope that someone can help me with my next modificaction. My 1998 F-250 LD 5.4 E4OD 2x4 has a Diablo Chip and a Flowmaster 40 with the exhaust exits before the rear tire. And now I want to add a Transgo Shift Kit and a Diablo Trans. Power Valve. But will the kit be too much for a power valve? Or with the chip the Power valve is all that I need?
When I have the Trans. pan down I will be installing a transmission temp. gauge and then the sensor will have to be braised to the pan. From what I read you have to drill a hole in the pan and then braise the nut and then install the temp. probe in the nut. Auto Meter instructions tell you more how to wire the gauge than the pan drilling.
