Sponsored by: Real Truck
Anyone Using Autotap???
Old Dec 27, 2003 | 04:59 AM
nafzimo's Avatar
nafzimo
I just got an Autotap! The problem is, I think it is going to create way more questions for me. For instance, I plugged it in and started looking at all the channels I could read and took data on the throttle position sensor. With the pedal all the way to the floor, I can only get it to read 93%. I hate to think that I could be missing out on a chance to dump 7% more fuel into the engine! Can I adjust it? Maybe it is just the catch-all floor mats holding it up.
Old Dec 27, 2003 | 08:12 AM
99f350sd's Avatar
99f350sd
The tps has little to do with major fuel deliery. The only thing the tps does is for idle, wide open for open loop and ac off and for a burst for accelleration...your MAF sensor takes care of your fuel delivery. As long as you are opening up all the way those readings are normal.
Old Dec 27, 2003 | 01:09 PM
nafzimo's Avatar
nafzimo
Yep, it opens all the way mechanically. I checked the Taurus and got a 93.7% reading. The truck was 93.3%. I just expected 0-100%.
