Intercooler Info Needed
Old Jan 20, 2004 | 07:58 AM
agelder's Avatar
agelder
Yeah, I'm one of the biggest PWs there (same handle) Only problem with it is that I start getting crazy ideas like camming and intercooling the regal.
That's what i was getting at with CobraXP, I just wasn't sure if all M90s had the same bolt patterns. I'd love to get my hands on an intercooler, but may end up trying to fab one before it's all done. The least expensive way to go at the moment is ZZP's intercooler, zzperformance.com, for the m90, and the best way to go is (as usual with different vendors, is hard to determine. ZZP has some good info on the workings of the M90 as well. Some will apply, some wont, but check it out (smaller pullies are fun)
Old Jan 27, 2004 | 05:39 AM
skipperw's Avatar
skipperw
I am the guy that MrRottnDog was talking about. Had the Kennedy Water Injection Kit installed. Works great. Quality product. It is set to automatically spray at 3500rpms into my Whipple Supercharger.
Old Jan 27, 2004 | 08:04 AM
agelder's Avatar
agelder
Why not go on a boost-activated switch if you go water injection, since knock tends to start at a certain pressure rather than RPM (dependent on ambient temperatures)? Is that an option for the system? Where do you get it?
Old Jan 27, 2004 | 08:21 AM
skipperw's Avatar
skipperw
You can buy it at: kennedysdynotune.com
Call Bob and ask him if you have any questions about it. He is an expert on the Kennebell and Whipple and made this Kit.
Old Jan 27, 2004 | 09:16 AM
MrRottnDog's Avatar
MrRottnDog
skipperw,
Have you had a chance to dyno it yet?
Old Jan 27, 2004 | 09:46 AM
CobraXP's Avatar
CobraXP
skipper - can you set it to spray at any rpm, or is 3500 the only setting?
Old Jan 27, 2004 | 11:16 AM
skipperw's Avatar
skipperw
Rottndog, going on Friday to Dyno it. Got Boost gauge hooked up this morning. Reads 6psi at WOT. Just talked to Pilot and he says I must order the 9lb pulley since I have the Water Injection Kit. Cobra, from what I understand, you dont need it until 3500 rpm. Call Bob Kennedy and ask him about it. I know that the Pilot, who did the install set it up that way and he is an expert mechanic about Superchargers. You guys should go to got-pressure.com There is a lot of information on that website. The guys that run it are Pilot and Crash who sell and install different brands of Blowers and Nitro systems.
