1978 - 1996 Big Bronco
Pics finaly
Old Dec 26, 2003 | 10:38 PM
Stomper4x4's Avatar
Stomper4x4
Pics finaly
Here is my Bronco that I bought about 8 months ago. IT's an 89 with a 351, C-6 tranny, manual hubs and transfer case etc. It runs and drives really well considering its age and mileage. I'm slowly fixing, changing and replacing parts to get it in tip top running shape. After that is done, the mods will come. Next on the list is PCV valve(see other post, what a PITA) new exhaust manifolds or headers, as I have an exhaust leak. Probably typical cracked manifold. Also, needs a new oil pan gasket, it has a slow leak. Then its repacking, and checking all wheel bearings, cv and u-joints etc. I'll probably do all the suspension bushings when I get around to doing a lift, though they seem real tight right now. Anyhow take a look and tell me what you think.
http://www.superford.org/registry/ve...il.php?id=4379
Old Dec 26, 2003 | 11:10 PM
steell's Avatar
steell
Looks a lot better than the 88 Bronco I got a month ago
Old Dec 27, 2003 | 12:01 AM
Blade_62's Avatar
Blade_62
Wow, I've never seen a white Bronco....at least not a white big bronco, I always see black/tan/silver...hmm
Old Dec 27, 2003 | 09:39 AM
3broncocrazy's Avatar
3broncocrazy
Nice looking bronco
Old Dec 27, 2003 | 11:31 AM
Stomper4x4's Avatar
Stomper4x4
Thanks for the compliments guys. I bought it because it is pretty straight and not a spot of rust anywhere. It also runs real well considering the age and all. Everything seems real tight. I'm just going through it, doing every maintenence item I can think of. Then I may do a few mods here and there, to make it a bit more trail worthy, if the cash flow holds out. I don't get out fourwheelin' that often, but a bit more beef would be nice for the times I do get it out in the dirt. I don't want to kill the on-road manners too much though, it actualy drives pretty nice.
