can anyone help me settle this?
Old Dec 26, 2003 | 07:57 PM
forddude05's Avatar
forddude05
Question can anyone help me settle this?
hey all-
can anyone help me settle an argument with a friend of mine about how many cams there are in these engines?
'00 5.4 PI in F250 SD 4x4
'96 4.0 Pushrod V6 in Explorer 4x4
i told him that there is only 1 cam in each... if either had 3-4 valves, then they would have to be DOHC. he says that if it's SOHC then it has 2 cams, 1 for each head; and if it's DOHC, then it's 2 cams/head.
so who's right??
thanks in advance
Old Dec 26, 2003 | 08:14 PM
stevieweevie's Avatar
stevieweevie
SOHC means Single Over Head Camshaft (just one cam per head). DOHC means Double Over Head Camshaft (two cams per head).
Old Dec 26, 2003 | 08:24 PM
Breeze's Avatar
Breeze
96 4.0 1 camshaft, traditional location in the block
00 5.4 is also 1 camshaft located in the head.
The terms SOHC and DOHC can both be looked at as being correct, as there is only ONE cam per head (SOHC) but since there are 2 heads on a V block engine, technically there are TWO cams overall (DOHC), also, the new 3 valve Triton engines still only use one camshaft per head
Old Dec 26, 2003 | 10:06 PM
EPNCSU2006's Avatar
EPNCSU2006
It's not DOHC. It's still SOHC, but there are two cams because there is a single cam over each head.
Total of 2 cams in the 5.4 and 1 in the 4.0.
Old Dec 26, 2003 | 10:46 PM
Breeze's Avatar
Breeze
Personally I refer to them as a SOHC also, one cam per head, same as the old 427SOHC, but you will run into people using the arguement that since it has 2 cams its a DOHC, I guess its all in how you look at it
Old Dec 26, 2003 | 10:50 PM
Breeze's Avatar
Breeze
I shoulda said 00 is also 1 camshaft in EACH head, 2 cams overall guess thats what I get for trying to work on to many things at once while sitting at the desk, LOL
Old Dec 27, 2003 | 03:58 AM
Torque1st's Avatar
Torque1st
Posting Legend
The terms SOHC and DOHC always refer to EACH head no matter how many heads it has.
