Brake Booster?
Old Dec 26, 2003 | 11:25 AM
bring2ya's Avatar
bring2ya
Question Brake Booster?
I ended up purchasing the Brake Booster on ebay and now am changing the front suspension (Gibbons Cordoba) can i use this booster with the original M/C to run the disc brakes and rear drums?
Old Dec 27, 2003 | 09:05 PM
Scot's Avatar
Scot
If you are referring to the Midland hydroboost, yes. I have been running that setup for about 13 years now. I pulled the residual valve in the stock m/c and added a 2 lbs front and 8 lbs rear after the T fitting coming out of the back of the h/b.
Old Dec 28, 2003 | 05:14 AM
Col Flashman's Avatar
Col Flashman
Re: Brake Booster?
It's actually a Midland Hy-Power & the answer is still yes.
Merry Holidays.
