Flywheel Woes
Old Dec 26, 2003 | 09:14 AM
78RangerXLT's Avatar
78RangerXLT
Flywheel Woes
Well, its happened on this truck as welll...
1978 F150 351M with c-6 auto
The old factory starter went out so I replaced it with an autozone one, that lasted two weeks. It started throwing out wrong and damaging my flywheel but it was too late, by the time I got my new starter and a shim it makes a horrible noise when starting and theres so bad a place on the flywheel that i have to get under the truck and rotate the engine a hair by the harmonic balancer (yes i know this is not the safest, but to get her cranked you do what you gotta do) ok so here it goes. I need a new flywheel, yes, but which one do I use? I see several different ones on sites some for 40 some for 63, some with different teeth and diff diameter holes. my vin is F15HNCE4726 if that helps.
Old Dec 26, 2003 | 09:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
moved to proper forum.
Old Dec 27, 2003 | 02:04 AM
Bill_Beyer's Avatar
Bill_Beyer
164 teeth 12 pitch. Here's a link:
Northern Auto
