4.0 temp guage?
Old Dec 25, 2003 | 11:14 PM
99xlt4.04x4's Avatar
99xlt4.04x4
4.0 temp guage?
On my 99 4.0 OHV, the temp guage rises to normal whane i start it, but after i go a few miles it starts heating up. It goes up tp the redline and stays about 10 seconds. Then it goes back down and stays at normal. It only does it when the engine is cold and only one time. I dont think it is a bad sensor or guage b/c the heater puts out really hot air when it says its hot.
Any suggestions?
Do you think it will mess up the engine since its only running hot for about 10 sec.?
Old Dec 28, 2003 | 09:21 PM
stupid red ranger's Avatar
stupid red ranger
try replacing the thermostat, it could be sticking a bit causing you to run hot intermitently. It is a cheap part, only about $10 bucks and only a 20 min job to change it out. While you're there change the temp gauge sending unit for another $10 bucks, aparently the sending units are pretty cheap and prone to failure. I just changed mine, I asked the guys on this forum for advice and many of them change thermostats, sending units with their coolant about every 2 years.
Old Jan 4, 2004 | 11:09 PM
99xlt4.04x4
Thanx. That worked. Along with changing the cofee colored coolant. I wouldnt have got the truck if i knew it wasnt taken care of.
Old Jan 4, 2004 | 11:12 PM
99xlt4.04x4
BTW the thermostat at Autozone or Advanced Auto ( I dont remember) was only $3.xx something and the seal was $2.09. The collant was more expensive than the parts! And it wasnt a 20 min job. But then again i had alot of cooling down time in there since i used flush kit and flushed the whole system while i was at it. I hooked the water hose right op to the block and let it flow til it was clear. No probs since.
