300 casting numbers?
Old Dec 25, 2003 | 08:46 PM
matt_302's Avatar
matt_302
Question,
Back in the 70's the car companies were trying to figure out what ways to save weight and that in turn would increace fuel economy. One way they achieved this was to make "thin wall" cast blocks to save wight (as much as 60 lbs. on a sb chevy). These lighter blocks reduced the strength of the base because of thinner head walls for coolant passages(no room for mistake when pocket porting) and also block passages more temperature sensative and cant stand as much power as the "thick wall" castings. Does anyone have any information at all on this subject particularly on the 300 I-6 model.
Thanks
Old Dec 25, 2003 | 09:53 PM
steell's Avatar
steell
You could aquire a selection of cylinder blocks from different years, and take them to a machine shop and have them sonic checked.
Of course we would expect you to post the results here.
Old Dec 25, 2003 | 10:07 PM
cdherman's Avatar
cdherman
As an avid reader and contributor for bout 8 months here and at fordsix.com, I have not heard of this being done in 240/300 blocks (same block, in case you didn't know).
The 300 has a very strong bottom end -- they might have done this, but it might just not matter. At least, as far as I know, when people build up a hot 300, they are not too troubled with the block. Forged cranks are interesting and nice (found in some HD engines), but don't seem to be all that necessary either.
You probably know all that. anyhow -- can't answer your question, but don't know if it matters.
Old Dec 25, 2003 | 10:08 PM
matt_302's Avatar
matt_302
OO kaaay, that would be one way to get results or someone could give me help as to a certain book that was printed such as there are for other V-8 confugurations. Another easier way is to find out what year the thick wall castings were last mass produced and go junkyard huntin. All I am asking is for that one piece of information mabey someone has. Unless you want to write a check out to me and ill most posotively get to finding out those specifics by sonic testing.
Old Dec 25, 2003 | 10:10 PM
matt_302's Avatar
matt_302
Thanx cdherman
palomino73
May 28, 2006 01:19 AM
averagef250
Apr 21, 2006 09:30 PM
dbc
Jun 14, 2003 10:11 AM
wl_keller
Apr 14, 2002 11:29 PM
