Flasher relay
Old Dec 25, 2003 | 06:54 PM
gfreek's Avatar
gfreek
Flasher relay
99 F150, XLT, 4X4, The problem is that I burn out the flasher unit under the dash. It stated blowing fuses, checked the wiring harness front to back. Nothing. Replaced the flasher, it controls hazards and signals, everything is good. then shortly the 4ways stop working, and haven't worked since. Turn signals work. I tow a trailer, but this happens without it connected. Any ideas before I replace it again??
Old Dec 25, 2003 | 07:53 PM
Mil1ion's Avatar
Mil1ion
Are you sure that is ONE flasher relay for BOTH?
For years they have been different,
Some fuse boxes are 2-piece boxes revealing the T/S flasher in behind
Old Dec 26, 2003 | 03:08 AM
gfreek's Avatar
gfreek
I am quite certain that there is only one for both, it's under the dash and sits in a terminal block with another relay. I'll ckeck it out again. The dealer, it is a dealer only item, told me there was only one, but did ask me if I had signals in my outside mirrors, whick I do not have.
