Low oil pressure
Old Dec 25, 2003 | 04:09 PM
Johnny Bravo's Avatar
Johnny Bravo
Low oil pressure
Anyone know why I have low oil pressure in a 1978 351M? I don't know how many miles, but it tends to happen at idle when the truck is well warmed up.
Old Dec 25, 2003 | 05:10 PM
79blueoval's Avatar
79blueoval
My guess would be worn mains and rod bearings.I have heard of guys using high volume oil pumps to cure this problem but to me this is not a cure but a bandage til it can be fixed properly.
Old Dec 25, 2003 | 05:57 PM
LxMan1's Avatar
LxMan1
Have you checked it with a mechanical gauge? What are the actual pressures?
I had a 71 351C that would not die. It held about 5lbs of pressure at idle and 20 wide open. I couldn't blow it up.
After 2 years of hard driving, I finally tore it down and found a main bearing that had overlapped about 1/2". It really was Ford Tough.
If the actual pressures are low, my guess would be worn main bearings.
If it doesn't knock, I'd drive her till she blows.
Or, you can tear it down and install a crank kit and other required pieces to rebuild it.
Jimmy
Old Dec 25, 2003 | 08:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to engine forum.
Old Dec 26, 2003 | 09:29 PM
Johnny Bravo
Thanks for your help guys.........if I tach it up it gets a little oil pressure back...... so we'll see how tough it is
