need help on steering cloumn
Old Dec 25, 2003 | 04:02 PM
tye sheats's Avatar
tye sheats
I have a 77 ford f-100 and the steering wheel has lots of "play" in it, is there a way to adjust that, or do i have to buy a new manual steering column, thanks tye
Old Dec 25, 2003 | 06:22 PM
76supercab2's Avatar
76supercab2
The problem is probably not the column. Is it a 2wd? If so there is a rag joint between the column and the steering box. The fiber disk of the coupler disintigrates and falls out. Then there are 2 safety pins that work in two overlarge slots to give the safety backup. However this causes a lot of slop in the steering. The rag joint is pretty straightforward to replace and you don't have to remove the column to do it. Just move the column up a little to gain clearance.
If you have a 4x4 then there is probably a U joint instead of a rag joint. These wear too. Do a search on this forum for replacement procedures.
Also, make sure all the linkages are tight and the king pins are free to turn.
Old Dec 25, 2003 | 08:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
The steering box can get play in it also but replacement units are available.
Old Dec 26, 2003 | 05:56 AM
335clevo's Avatar
335clevo
The steering box has a little nut with a screw inside it. Straighten the wheels, loosen the nut and do up the screw bit by bit, while moving the steering wheel back and fourth a little bit. This will take a lot of play out of the steering. Once you are finished, tighten the nut again.
335C
Old Dec 26, 2003 | 12:19 PM
tye sheats's Avatar
tye sheats
yes the truck is 4x4, thanks for the replyies, i'll try them this weekend
Old Dec 26, 2003 | 06:23 PM
plowpusher's Avatar
plowpusher
if you tighten up the steering box test drive it make sure the wheel will return to center after making a turn if it doesn't you got it too tight check tie rod ends and pitman arm for excess play wheel bearings for loosness ball joints on FWD axles
