Oil & Lubrication
Transmission Fluid
Old Dec 25, 2003 | 09:29 AM
sotxford's Avatar
sotxford
Transmission Fluid
I know this might seem like a silly question for some of you, but i don't know. SO, what is the difference between TYPE a and Dexron III/Mercon??? And what if you mix them in your Tranny---OOPS!!!
Old Dec 25, 2003 | 09:55 AM
Beast12's Avatar
Beast12
Ummmm......I don't think you want to do that. I could be wrong though. If they are not compatible then you need to do a fluid change. You mine as well do a filter change too. I wouldn't drive it until you get other opinions.
-Matt
Old Dec 25, 2003 | 07:55 PM
MrBSS's Avatar
MrBSS
Not familiar with type A, but generally speaking, it is very important to use the ATF that your owner's manual specifies. However, if the amount involved is a quart or less, it'll probably be O.K.
Old Dec 26, 2003 | 09:01 AM
jim henderson's Avatar
jim henderson
I would still recommend changing the fluid to be safe. I was aware of only Mercon/Dexron and type F fluids. Type A is either news to me or lost in my foggy mind since you rarely if ever see it, be my guess.
The fluids have different characteristics and have different friction modifiers. If the modifiers in type A are wrong for your tranny they would lessen the effectivemness in the Mercon and could lead to subtle increased wear. A lot would also depend on how much mixing you have, 1 qt might be no cause for alarm, half the total fluid might be a problem.
Also depends on whether you have a manual tranny or auto. On autos the fluid is fairly picky. On manuals you can get away with a lot more.
This is all wild, slightly educated guessing on my part. But I would change out the fluid and maybe the filter. The filter holds an insignificant amount of fluid as compared to what remains left behind in the cooler, torque converter, tranny passages and valve body. Fluid is cheap compared to a rebuild.
Of course if one of the tranny experts or shop owners speaks up I would believe their opinion far more than my own, like I said I am guessing here.
Good Luck,
Jim Henderson
Old Dec 26, 2003 | 09:51 AM
Beast12's Avatar
Beast12
We have a *cough* GMC *cough* bucket truck at work that uses Type 'A' transmission fluid for the power steering reservoir. Never have seen anywhere to buy it. Oh well, guess we are fine until we spring a leak!
-Matt
Old Dec 26, 2003 | 10:42 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Type A is an obsolete fluid formerly specified for Chrysler automobiles. It has no friction modifier or detergent qualities. Where on earth did you find it? Did you discover Grandpa's stash?
Oh wait on second thought, the companies that sell the SA grade motor oil to the convienience stores may also be marketing Type A fluid. It may also be sold as expensive racing fluid. In any case, if you have any, I would just give it to someone you didn't like.
Old Dec 26, 2003 | 10:44 AM
Beast12's Avatar
Beast12
Give it to me.....our bucket truck needs it for the power steering! I know something is going to fail soon!
-Matt
