Sponsored by: Auxito
Performance Ignition Systems???
Old Dec 24, 2003 | 07:30 PM
mcdev's Avatar
mcdev
Happy Holidays all! I have a misfire with at least one cylinder in my truck (#8). I have no problem changing it out, but I am told that I may end up changing all 8 Coil on Plugs in the process or correcting this miss. I am wondering if there is a good aftermarket ignition system available. If i am going to spend the money on 8 new COPs I figure I may as well get a good MSD system. Any suggestions would be great. Thanks guys!
Old Dec 24, 2003 | 11:09 PM
LxMan1's Avatar
LxMan1
I haven't seen any at this time. Usually it is the rear coils that fail, either due to moisture or just from the heat back there under the cowl.
If it coded #8, then you should be fine just replacing that one.
Jimmy
