1978 - 1996 Big Bronco
Strange problem
Old Dec 24, 2003 | 08:08 AM
BillyBob69's Avatar
BillyBob69
ok all you damn geinuses.....I got one of the bottom bolts off to the shield plate in front of the damn filter, but one, even after soaking for a couple of hours, wont budge. AHHHHHHHH Any ideas or maybe some funky spray that will help it come off? (Getting out the cuttin torch!)
Old Dec 24, 2003 | 10:03 AM
Bronco86's Avatar
Bronco86
mine did the same, i used a 3/4 drive and socket
good luck
Old Dec 27, 2003 | 12:38 PM
BillyBob69's Avatar
BillyBob69
I tried that, even with a cheater bar of sorts...it started to strip so I stpped and put a wrench on it with a cheater bar...about a 1 footer. Still wont move.
Old Dec 27, 2003 | 08:52 PM
mustangman65_79's Avatar
mustangman65_79
so u still don't have it off?
Old Dec 28, 2003 | 06:28 PM
BillyBob69's Avatar
BillyBob69
Nope still on there. I was thinking of getting a set of Vise grips and seeing if I can muscle it off. Then replacing the bolt.
Old Dec 29, 2003 | 05:09 AM
mustangman65_79
would a stud remover work?
Old Dec 29, 2003 | 07:59 AM
BillyBob69's Avatar
BillyBob69
Oh the bolt is still in one piece, and if I use a wrench I still get a good bite on it, just wont break free.
Old Dec 29, 2003 | 08:01 AM
mustangman65_79
Damn, mine was easy, came right out, sorry it's being so bad my friend. I can only say, just keep trying.
Old Dec 29, 2003 | 12:29 PM
tHeCoS's Avatar
tHeCoS
another way to relieve fuel pressure, there is an inertia switch under the dash on the fire wall. Pry the button up with a screw driver and start the engine a couple of times. Pressure is relieved. After writing this, I don't know if that switch is on the '85? it's on my '90, though
Old Dec 29, 2003 | 12:35 PM
Bronco86's Avatar
Bronco86
ya their is a switch on older models....try this get a good bite and try to tap it loose....just a thought (i'm sure you prob have already tried this)...all else fails cut the b!t^&.....
Old Dec 29, 2003 | 01:02 PM
BillyBob69's Avatar
BillyBob69
Well I am planning on making a trip to the tool store today on my way home and get something there to remove it. Prolly vise grips or something. I was just hoping that there was something like a spry that was real good that would help in breaking it loose. Ah well, guess brute force will have to come into play on this one. Thanks guys!
Old Dec 29, 2003 | 01:21 PM
tHeCoS's Avatar
tHeCoS
"liquid wrench" with a combination of elbow grease always works for me. 'just keepin it live'
Old Dec 29, 2003 | 02:27 PM
  #28
BillyBob69's Avatar
BillyBob69
OK I feel like an idiot...after going thru the Haynes manual, I found that there is on bolt on the bottom of the shield and one on top. There is another bolt on the bottom, or so I thought. Looks like its just a dummy bolt. Not meant to be removed. The manual has about 4 pics and show 1 top and 1 bottom. DOH!
kimryward
Jan 7, 2017 02:48 AM
zoomanmc
Nov 27, 2015 07:59 PM
Gwp51
34
Jul 17, 2015 06:26 PM
X JBM X
18
Aug 30, 2010 10:25 PM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
24
Jun 18, 2004 05:53 PM
