Oil Leak
Old Dec 22, 2003 | 10:29 PM
rmilchman's Avatar
rmilchman
Oil Leak
Last year I had a leak and the mechanic said it was coming from a valve and tightened it. I saw oil on the bottom of pan. Just noticed oil dripping again, this time it's coming form the passenger side. I can see it on the exhaust pipe and starter. The truck is a 2002, are they known for oil leaks? I'm running a 60HP programmer, could this have anything to do with it?
Thanks,
Rich
Old Dec 23, 2003 | 06:39 AM
powerstroker250's Avatar
powerstroker250
Check the TOP of the engine, most oil leaks originate from there.
Old Dec 23, 2003 | 07:34 AM
rmilchman's Avatar
rmilchman
It' still under warrenty so I'll bring it in. I just hate the thought of getting harrassed again. lat year they gave me a hard time for having an aftermarket air filter, and chip. Then they said I caused the problem from over filling. When I called them on the over filling part, they said it wasn't over filled and they found the leak. I believe they said it was a deader valve (whatever that is). It's also interesting last year when it leaked it was about the same time of the year.
