half full shows empty
Old Dec 22, 2003 | 08:59 PM
earl_change's Avatar
earl_change
hey yall,
I have a 85 f150 with dual tanks and ever since i have owned the truck the fuel gauge slowly drops to empty when there is still about half a tank of gas. This happens on both tanks. does anybody know if there is a simple solution to this problem. i have replaced the fuel gauge with one from the local junk yard and it behaved the same way. any suggestions would be welcomed.
thanks.
earl.
Old Dec 22, 2003 | 09:20 PM
christaylor's Avatar
christaylor
Mine does the sameting unless the other tank is empty then i run out of gas before I get to the station.lol I hate that!!!
Old Dec 23, 2003 | 03:21 PM
bigric's Avatar
bigric
Probably the sender. If you've got EFI, the sender is attached to the in-tank pump. I had this same problem in an '86 Bronco.
Old Dec 23, 2003 | 03:27 PM
Manwith3fords's Avatar
Manwith3fords
Check for a soldered connection in the wiring near the front tank. It will have 2 wires soldered to 1 wire and it is connected to the sending unit. My truck acted the same way, even with a new sending unit so I inspected the wiring and found a very corroded connection.
