Offroad & 4x4
Removing Rivots?
Old Dec 21, 2003 | 10:19 PM
spencry25's Avatar
spencry25
Removing Rivots?
I'm putting a lift on my 93 F-150 and it's time for the radius arm drop brackets. Left side no problem, all nuts and bolts. Right side a different story. I remeber doing this on my '76 a few years back and a real pain in the #ss. I drilled them all out then, but know there has to be an easier way. Was thinking about using a saws-all for the heads. If I do end up drilling again what's the best type of bit? Thanks.
Old Dec 22, 2003 | 12:18 AM
rlh's Avatar
rlh
I would use an air chisel on the large ones if you can get a clear shot on them. The air chisel would give a hard, smooth whack on the thing. Its more difficult to get a clean crisp whack with a hand chisel and hammer plus theres the risk of glancing blows with hand tools. If I used a drill, I would go with titanium and use the proper bit oil to keep the bit from over heating and gauling and breaking as a result. You could drill a smaller, pilot hole first then use a larger bit.
Old Dec 22, 2003 | 12:43 AM
fishmanndotcom's Avatar
fishmanndotcom
best way to do it is find someone with a acytelene torch and blow them straight out. Took me about 15 minutes to do all the rivets on my old 93 F-150.
another option is to cut the heads off with a ziz wheel and then tap the rest out with a hammer.
-jason-
Old Dec 22, 2003 | 12:59 AM
Ryan50hrl's Avatar
Ryan50hrl
Plasma cutter.....gotta love em....i only wish i had one here at home.
Old Dec 22, 2003 | 01:01 AM
fishmanndotcom
Old Dec 22, 2003 | 01:08 AM
rlh's Avatar
rlh
I think I'm in tall cotton with an air chisel.
Old Dec 22, 2003 | 07:40 PM
natewoz's Avatar
natewoz
I wouldn't torch on the frame. That heat can affect the steel in unpredictable ways. I'm going to be grinding them.
Old Dec 23, 2003 | 07:13 AM
fishmanndotcom
i have done several with a torch and as long as you keep the heat on the rivet it won't affect anything else.
lol, i hope you got some time have fun.
-jason-
BTW...I am in the same boat, I am going today to put a 6" under a buddies truck and he is gonna grind.
Old Dec 23, 2003 | 08:21 AM
kjett's Avatar
kjett
I had all the rivets of mine and the donor trucks brackets off in about an hour and a half, but then again, I took the track bar bracket off the donor and center brackets on my 95 when I did the SAS. I just used an air chisel to pop the heads and then swapped bits in the chisel to punch the rest of the rivet out. Went like Butter, just got to keep the chisel trimmed up and sharp!
Old Dec 23, 2003 | 10:57 AM
MustangGT221's Avatar
MustangGT221
I had all the rivets to do on the crossmember brackets, and the radius arms. I used a grinder to grind the head off the rivet, then used an air chisel to punch the rest out.
Old Dec 23, 2003 | 11:23 AM
rebocardo's Avatar
rebocardo
What I do is center punch the rivet head. Then drill small bits all the way through until I am up to about 1/8. One reason is so you know where the center of the rivet is after grinding and because you might want to do more drilling.
Then grind the head off. Then air hammer the rest of the rivet out. Sometimes on the older iron (Fords) you will need to drill a bigger hole to relieve the pressure on the rivet. On some I have drilled it all the way out, using gradual steps in drill size, until only a shell remained of the rivet and then pulled it out with needle nose.
A grinder (if it fits) or a cut off wheel will take a rivet off in no time if your compressor is large enough.
