thermostat??
Old Dec 21, 2003 | 05:13 PM
dsinmo's Avatar
dsinmo
thermostat??
Hi everybody...........
I have a '98 Ranger regular cab, 4 cyl............. heater quit blowing hot, doesn't even get lukewarm. Figured I'd change the thermostat first, done that lots of times before......... NO BIG DEAL, right? No problem.......... except I take off the top rad. hose, and the thermostat housing apparently maybe is not that? Nothing in there....... so I thought I would try to take off the housing, except all the bolts are hidden behind and under the timing belt housing, which I tried to remove (only the housing)......... so that's where I'm at. Anyone changed the thermostat on theirs before?? I wouldn't think it should be THAT hard......... heck I've done it LOTS of times before.....
Any help or comments would be much appreciated. Thanks.......
Dave Scott
Old Dec 21, 2003 | 05:25 PM
Dealford's Avatar
Dealford
Welcome to FTE dsinmo.
You're on the right track. The 4banger is the knocker to change. Continue on removing the upper t/b cover to get at the t/stat housing bolts.
Old Dec 21, 2003 | 05:57 PM
dsinmo's Avatar
dsinmo
there's an upper timing belt cover?
Old Dec 21, 2003 | 07:08 PM
Dealford's Avatar
Dealford
My apologies. I was thinking about something else all together. To get at the bolt that is at about 4 o'clock it is easier to take off the front timing cover. The one at 10 o'clock can be had with a 6" extention.
Old Dec 21, 2003 | 07:39 PM
dsinmo's Avatar
dsinmo
HHmmm, ok thanks......
How many bolts are there to remove the thermostat housing? If I take off the timing belt cover, how many bolts are there? I found one pretty much center on the cover, but it seems like there's another one way down deep under something else, is that right?
Geeezzzzz after changing thermostats on a 71 Torino, and my old 79 GMC and a 78 Chevy truck, among others, I would have never guessed it would be like this, hahahaa.
Oh..... your signature..... "It ain't fun unless it's done the hard way"..... I'm afraid I disagree, my friend, haha. Thanks for your help, I really appreciate it.
Old Dec 21, 2003 | 07:48 PM
Dealford's Avatar
Dealford
If memory serves, there is 1 bolt and 7 clips, including 1 at the bottom and 1 just above the pulley, for the t/cover.
The housing has 2 bolts.
Old Dec 21, 2003 | 08:01 PM
dsinmo's Avatar
dsinmo
Thanks, Deal, I'm gonna give it a go.......
