This is a new twist to your old thread. I found my local dealer will sell me a 2001 headlight switch with the fog light option part #1C32-11654-BAA per an old thread.. Now for the questions. Is this the correct switch? Then if it is where do I pick up the harness to tap in my new lights? Thanks in advance for you help!!
Ford would be happy to sell you one for about $400. Of you could scrounge up some terminals, solder some ends on and after visiting splice city...voila'!
At least that's what I did.
-CRJ
2kXV10 lmt on Weld 16x10 'phoons w/35 x 12.5 AT's. ProComp/Liftmaster 6" lift and 6x Rancho 9000's, Superchips 1715 tuner, K&N intake, AirRaid throttle body spacer, cat back 3" sst exhaust into FM70 big block, 2.5" dual out.
