Door wont open
Old Dec 20, 2003 | 02:52 PM
christaylor's Avatar
christaylor
Door wont open
95 explorer Rear drover side door does not open from the inside. How is the handle attached to the latch?
Easy repair or should I take it somewhere?
Old Dec 20, 2003 | 03:05 PM
87 XLT's Avatar
87 XLT
Go to Autozone & spend 15 bucks for a Haynes manual and then fix it yourself.
Old Dec 20, 2003 | 08:31 PM
96explorereddieb's Avatar
96explorereddieb
And the door handle is $12 at the dealer so it's a very cheap fix.
Old Dec 20, 2003 | 10:37 PM
Tourist's Avatar
Tourist
Been there done that. its an easy fix. Take door panel off. 2 screws for handle. remove from metal rod. do complete oppisite to put back together. Go to the boon yard and get one for 5 bucks!
Old Dec 21, 2003 | 02:12 AM
Jet Lizard's Avatar
Jet Lizard
But before buying the handle, just check the child lock. I've seen many people coming with complaints on rear doors that don't open from the inside. In most cases it was exactly child lock activated.
One friend of mine even disassembled the door looking for the source of the problem! And it was, again, the activated child lock.
With best regards,
Yuri
Old Dec 21, 2003 | 07:20 AM
christaylor
Thanks Child lock was the first thing I checked. Any special tips for removing the door panel??
Old Dec 22, 2003 | 07:56 AM
mason's Avatar
mason
I have replaced a few of these handles in both of my Explorers. As said above an easy fix. The panel is held on with plastic push fasteners so you can remove by simply prying the off starting at the bottom corner. My son broke another one a few weeks ago. The price at the local dealer had gone up to $19! They were less than $12 not too long ago. I felt ripped off.
Mason
Old Dec 24, 2003 | 11:21 AM
ottosmom's Avatar
ottosmom
Mine doesn't open from the inside OR the outside. Easy fix? Can I get the door panel off with the door closed?
Old Dec 24, 2003 | 11:29 AM
mason's Avatar
mason
I'd try a body shop.
Mason
Old Dec 15, 2004 | 04:54 PM
wendy213's Avatar
wendy213
have same problem but cant afford body shop $170- to $256 dollers they wont to fix it. if i can would love to do it myself also you take pannel off with the door stuck in the closed position if so how? and if so many people are having this problem why isnt thier a recall for it?.
Old Dec 16, 2004 | 05:05 AM
marragtop's Avatar
marragtop
I don't think you will be able to get the door panel off with the door shut without tearing the panel up. It seems unusual that both the internal and external door handles would go bad at the same time, so I suspect your problem is linkage related. Try and find a mechanic that knows how to 'slim jim' the door. They can usually do that in less than 5 minutes. At that point the door will be open.
Mike
Old Dec 16, 2004 | 07:40 AM
K2JJB's Avatar
K2JJB
I'm not sure that the panel can be easily removed (i.e. pulled away to release all the little clips) when the seat is in the way. Maybe if you slide the passenger front seat all the way back and can get the passenger rear seat out somehow (I have never tried doing that) you might be able to work on the panel with the door closed?
