Tach Redline
Old Dec 20, 2003 | 11:56 AM
Stingray42's Avatar
Stingray42
Tach Redline
I just installed a tach in my 84 Ford F150. I need to know what I should set the redline at. It has a 351W and a 4 speed. IT had 258,000km on it, but I feel it has been rebuilt because it has between 140-160 lbs of compression in every cylinder. I do not use the tach to drive the truck, more the sound of the engine, but i want to see that I am shifting at the right time, and it is nice to have it there.
I mounted it under the dash, looks pretty slick, I will post pics later!
Thanks!!!2
Old Dec 20, 2003 | 11:44 PM
Stingray42's Avatar
Stingray42
ttt
Old Dec 21, 2003 | 12:19 AM
mustange70's Avatar
mustange70
i would set it no more then 5000 but because of the higher comp(it should be more in the area of 120-130) you could probably go up to 5500.
BTW it wouldn't happen to be an HO would it?
Old Dec 21, 2003 | 12:51 AM
Stingray42's Avatar
Stingray42
how would i find out if its an HO?
everyone else, does 5k sound good like mustang said?
Old Dec 21, 2003 | 12:54 PM
Txquadhunter24's Avatar
Txquadhunter24
HO 351 came from the Factory with 4V carbs. most all V-8's use a 5,000RPM redline unless built to run higher RPM's. So I'd agree with it.
Old Dec 21, 2003 | 02:41 PM
Stingray42's Avatar
Stingray42
ok, sounds good, mine has a 2 barrel, so i guess it is not an HO huh?
Thanks guys!
