1978 - 1996 Big Bronco
new bushing install
Old Dec 20, 2003 | 10:38 AM
2xcrash's Avatar
2xcrash
Unhappy new bushing install
I want to install new bushings on my front end. its a 1990 bronco with a rancho 4" lift. on a scale of 1-10 how hard will this be for a novice mech. and will i need speical tools?
Old Dec 20, 2003 | 12:12 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I asume you meen the radius arm bushings.
There not too hard, it just takes time. I found that its nice too just take the nuts off the back side of the radius arms, then unbolt the sway bar, you might have to unbolt the coil springs, but either way, you have to then pull the traction beam forward, so that the threaded part of the arm is out of the mount.
hope this helps.
