Egr Need Help
Old Dec 19, 2003 | 11:36 PM
ARNO60's Avatar
ARNO60
Egr Need Help
I WAS TOLD TO CHECK MY EGR VALVE FOR THE POOR RUNNING COND.IN MY 1992 F-150 5.0 AT LOW RPM DRIVING.CAN ANYONE TELL ME HOW TO CHECK THE EGR .THANKS
Old Dec 20, 2003 | 01:18 AM
LxMan1's Avatar
LxMan1
Well, first, remove the 3 nuts or bolts that hold the sensor on top of the valve. With it plugged up, push in the plunger on the bottom of it while the truck is idling. It should change the idle speed. If not, it could be faulty.
Second, remove the EGR valve and spray some carb cleaner into the hole on the bottom with the poppet valve in it while holding it upside down. It should hold the cleaner if it is shutting off properly. If not, then I would replace the valve. They get carboned up over time and this causes then not to shut off completely and can make the engine surge at low rpm.
Jimmy
Old Dec 26, 2003 | 08:48 PM
bob arrington's Avatar
bob arrington
disconnect the vacume line to it and plug the vacum line if yourengine runs better its bad
