Squeaky Clutch Action
Old Dec 19, 2003 | 09:18 PM
bunting1's Avatar
bunting1
I have a 2003 Ranger XL regular cab with a manual transmission. When I engage the clutch, I get an annoying squeaking sound.
Any suggestions? I only have 7,400 miles on the truck so the warranty is not an issue. I am not sure if the spring on the clutch housing needs WD40 or if there may be other issues.
Old Dec 19, 2003 | 09:48 PM
zoti's Avatar
zoti
I have the same thing on my 96 2300. Annoying squeek when I press on the clutch. I tried to find where it's comming from but it seems to come from the clutch pedal cylinder so not much oiling is going to go there.
Anyone with a better idea ?
Old Dec 19, 2003 | 10:49 PM
jessfactor's Avatar
jessfactor
if you look in the haynes manual it gives a few lubrication points to stop the squeeking. check the maintenence section. dont use wd-40, use a greese gun or some of the white crap you can just scoop up w/your finger.
Old Dec 20, 2003 | 03:39 PM
zoti's Avatar
zoti
I have teh chilton book and it doesn't mention any lubrication points. Can you scan an image of the lub points off the haynes manual ?
Old Jan 7, 2004 | 10:59 AM
mikejk's Avatar
mikejk
Any update on this issue?? I have the same problem on my 96 B400 I cannot find any points to grease?
Old Jan 7, 2004 | 12:28 PM
zoti's Avatar
zoti
Unfortunately no updates.
Old Jan 7, 2004 | 09:02 PM
hreed's Avatar
hreed
Stay away from WD-40. As a lubricant it is not good. Get some LPS-2. Much better.
