I have a 1994 F150 6 cyl and would like to replace with a 94 Mustang GT engine. Will the harness connect to the Mustang engine and also the computer. Don
I wouldn't think that the six computer would work on a v8, because i'd assume the computers are programed or designed to only fire the spark plugs and injectors that it was designed for.
I hope you are a Master Mechanic. You may be creating a back yard ornament. Sounds like alot of work and money.
I would probably try to get the engine installed and then find a good aftermarket computer/harness that will give you some flexibility when installing the electrical system. Good Luck
