Sponsored by: Real Truck
Seat belt warning beeper
Old Nov 13, 2002 | 06:17 PM
vogtjim's Avatar
vogtjim
Does anyone know how to disconnect the warning beeper for the seat belts on my '02 SD?
Old Nov 13, 2002 | 06:19 PM
Yeti's Avatar
Yeti
Nope, but a temp fix that works on a 01 is just to push the lock button, and it will disable it until you start the truck again.
Old Nov 13, 2002 | 06:20 PM
Waxy's Avatar
Waxy
I'm not sure it can be completely disconnected, but if you check your owners manual there's a rather complicated procedure in there to turn off the "Belt Minder" feature that causes the beeper to go off ever few minutes. It involves hooking and unhooking the seat belt a few times and turning the ignition on and off I believe. Just follow the steps and you should be beeper free.
Good luck,
Waxy
Old Nov 13, 2002 | 06:32 PM
Tlattin's Avatar
Tlattin
I unplugged mine under the seat.
Old Nov 13, 2002 | 08:46 PM
nafzimo's Avatar
nafzimo
[updated:LAST EDITED ON 13-Nov-02 AT 09:47 PM (EST)]If you are talking about the "BeltMinder" feature, where the chime sounds for 6 seconds every 30 seconds for the first 5 minutes (geez that sounds confusing), See page 103 of the Owner's Guide on how to disable it. I did and have not missed it a bit! I also disabled the annoying AutoLock feature (see page 88). Good luck, the directions are a bit tricky and involve a live chicken. :-)
Matt
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control, Flowmaster 40
Old Nov 13, 2002 | 08:49 PM
Yeti's Avatar
Yeti
I see this thread going down hill
Old Nov 15, 2002 | 08:11 PM
Tlattin's Avatar
Tlattin
I missed page 102 in the owner's manual. Thanks vogtjim for bringing this up.
I wonder if the seat belt wiring ties into the airbags somehow? I was running with it unplugged is why I ask.
Old Nov 16, 2002 | 12:02 AM
superv10's Avatar
superv10
I had also done the "unplug under the seat" - I think that messes up the airbag stuff - so instead, I plugged it back in, and used the procedure in the manual.
btw, it's page 107 and 108 (at least for the 2002 manual)..
Old Nov 16, 2002 | 12:35 PM
vogtjim's Avatar
vogtjim
Thanks everyone, I guess I should have looked in the book first. It worked just like it said it would.
Old Nov 17, 2002 | 11:28 AM
nafzimo's Avatar
nafzimo
>manual)..
Now wait a minute... I have a 2002 manual and it is page 103. Either you have extra pages or I got shorted. Are there different versions of the manual?
Old Nov 19, 2002 | 09:18 PM
ke6jcf's Avatar
ke6jcf
Old Nov 19, 2002 | 10:24 PM
superv10's Avatar
superv10
The manual that came with my truck says on the front:
Owner's Guide
F-250/350/450/550
Super Duty F-Series
2002 Model Year
Page 103 has a picture of how to adjust the belt height. The procedure to disable the chimd begins on page 107.
My whole manual has 304 pages...
Maybe it's different??
-superV10
Old Nov 20, 2002 | 09:54 PM
nafzimo's Avatar
nafzimo
>Owner's Guide
>F-250/350/450/550
>Super Duty F-Series
>2002 Model Year
Cover is the same on mine!
Page 99 has the belt height adjustment pic in my book.
Page 103 has the chime disable procedure.
Mine has 304 pages but 301 - 304 are all blank.
Page 3 says copyright 2001 at the bottom.
Strange.
Matt
Old Nov 21, 2002 | 07:16 AM
mgriffin's Avatar
mgriffin
Page 74 in a 2003 manual
Old Apr 25, 2004 | 12:04 AM
jamesf150's Avatar
jamesf150
Talking
Wonder if someone could just post the procedure here, if it's not too much trouble - say for a 2003 and 2004 - I'd think they'd be the same. ? .
