Starts then stalls
Old Dec 19, 2003 | 03:07 PM
Fordman063's Avatar
Fordman063
Starts then stalls
1999 Expedition will not run after it starts unless I use the accelerator to keep the RPM above 600. In other words it will not idle by it-self. Also the service engine light soon, has come on and does not go out.
Is there a sensor that needs to be changed or could it be a fuel filter. I thought maybe the injectors were dirty and ran a bottle of cleaner thru them, but no help.
Old Dec 19, 2003 | 04:04 PM
BigMan69's Avatar
BigMan69
IAC Valve. They are notorious to go bad at about the 50,000 mile mark. Those are the tell-tale symptoms, you described. Very easy to change, 2 bolts and a wire plug. Runs about $60.
BigMan69
Old Dec 19, 2003 | 04:23 PM
scottskingdom's Avatar
scottskingdom
my 92 f250 99000 = 2 replaced IAC valves.....and counting!
sometimes cleaning with gumout buys time -sometimes it doesn't and ya need a new one.
Old Dec 19, 2003 | 06:15 PM
Fordman063's Avatar
Fordman063
Thanks for the input. Soon as it quits snowing here I'll put a new IAC in.
