tranny help
Old Dec 19, 2003 | 09:35 AM
the real Broncoholic's Avatar
tranny help
ok
heres the prob. I have the e4od tranny it was rebuilt 16 months ago
no problems till last nite
I was only 1/2 mi from home, I stopped at the stop sign and then couldn't go any farther it wouldn't go forward or reverse I even tried puting it in 4x4 to see if it was just a drive shaft but it wasn't
so I ran home litirealy and got the tractor and my lil brother and pulled it home
this morning I tried it again it moved about a foot and wouldn't go any more
fluid level is fine, no leaks anywhere it does make a slight grinding/spinning noise periodicaly while in park
First can anyone tell me whats wrong? Besides that I bought a Bronco with the e4od
and second who knows if I can swap in a aod or c6 without any problems?
Old Dec 19, 2003 | 11:43 AM
RTM's Avatar
RTM
I can't answer your tranny ? but I believe you will have a computer issue installing a C-6 since the computer is monitoring for the E4OD.
I may not have helped much but your post will be kept alive a little longer.
Old Dec 19, 2003 | 02:38 PM
hat I knew I want to know if ther would be anyway around that prob. and if a aod will bolt right in?
Old Dec 22, 2003 | 01:54 PM
ANYBODY I know someone out there can help me.
