diablo chip for a bronco?
https://www.ford-trucks.com/articles...CU-locator.jpg
If you don't see the code on the engine compartment side then
disconnect the battery, and remove the box. You'll see the PCM code on it on the inside of the cab side of the box.
Here's what it looks like:
https://www.ford-trucks.com/articles...02/ECU-out.jpg
In the above example, its U2D. It will always be the largest type font on the sticker.
Post the code and I'll let you know.
You can get the chip here:
http://www.motorhaven.com/customer/home.php?cat=37
thanks
