Computer Chips & Tuners
Radical cams, and computers....
Old Dec 18, 2003 | 09:56 PM
pfogle's Avatar
pfogle
MY quiestion is this, if I run a regualted vacuum pot to keep the required amount of vacuum flowing to the computer would it be possible to run a high lift cam with a stock computer? (modified for fuel mixture of course.)
Old Dec 19, 2003 | 07:03 AM
FTE Ken's Avatar
FTE Ken
Question... what will you be using to keep the A/F ratio correct across the RPM range? What are the cam specs?
Old Dec 19, 2003 | 09:41 PM
pfogle's Avatar
pfogle
haven't gotten that far into it yet, wanting it to lope enough to scare people, but retain a streetable state, I'd thought about a mass air conversion.
Old Dec 24, 2003 | 01:16 AM
FTE Ken's Avatar
FTE Ken
Okay... I highly recommend you go with mass air. Speed density can't deal with cam changes and will require custom tuning with just about any cam. With MAF, its not as critical but if you change cam timing it would require programming changes even with mass air.
