351C Intake suggestions
Old Dec 18, 2003 | 09:33 PM
Crazy Canuck's Avatar
Crazy Canuck
I have a 351C. I am putting in comp cams 268 and am looking for a 4 barrel intake. I wanted the performer RPM but they don't make one. Any suggestions are more than appreciated.
thanks
Old Dec 24, 2003 | 04:26 PM
mudcobra's Avatar
mudcobra
Are you using 2V heads or 4V heads?
Old Jan 7, 2004 | 06:24 PM
Crazy Canuck
2V heads.
Old Jan 8, 2004 | 10:20 AM
mudcobra's Avatar
mudcobra
I just checked, Edelbrock Performer #2750 for Ford 351C w/2bbl heads is available. It is a dual plane intake that works off idle to 5500 rpm. I used a slight variation of this intake on a Cleveland once and liked it quite well. I think the part # was F351-2V. Not sure if it is still made anymore. Weiand also makes a nice intake #7516 that would have the characteristics of a Performer RPM if it was made. Never had any expierance with it, but it is a single plane intake for the 1500-6500 rpm range. The Edlebrock intake might be better suited to your needs if you are building a mild street engine for everyday use.
Old Jan 9, 2004 | 01:05 PM
JoeP's Avatar
JoeP
How can you tell a 4V head from a 2V head?
Old Jan 10, 2004 | 05:47 PM
Matts72's Avatar
Matts72
There is a 4 cast in the corner of the 4V heads.
Old Jan 11, 2004 | 08:20 PM
pcmenten's Avatar
pcmenten
Crazy Canuck, to me there is only one intake manifold for the 2v 351c - the Aussie iron 4bbl intake. (I've got two.) A fella named Phil in Portland, OR sells them. If you want, I can get you his email address.
