Ratsmoker, I got a question for you...
actually a request/question, TheWiz427 said you might have desktop dyno software, question is, would you be willing to run a couple of engine combinations? If your interested you can check the windsor section or follow the link below, if you don't have time or interest, no big deal, I understand fully. Thank you for your time
https://www.ford-trucks.com/forums/s...18#post1175418
I've got DD2000, and I'd be happy to run it for you, but some people on this board have ridiculed it's accuracy. I still think it's fairly accurate. Let me know.
Edit: I'm gonna need the opening and closing events for those cams listed. Seat to seat timings would be most accurate.
rusty70f100
I posted all the cam specs avaiable to me on the other thread, the powermax specs are complete but the comp specs are questionable as to whether you'll have enough data to list. Well see what you can do if you have the time and interest. Either way I appreciate your taking a look. later
Ratsmoker
Korea? If I haven't purchased the cam by then, I will get back to you, to do some comparing. Thanks
rusty70f100
Thank again for sending those graphs to me. The 270H magnum and the XE268H were close, one favored a little more torque the XE and the other a couple of more hp, still very close. Appears the XE is still the winner. I was shocked at the XE268H graph, 374 tq at 3500 estimate and over 350 tq from 2000 to 4500 should that be realistic that thing should perform just fine. I think your right it appear the software you used might be optimistic. I guess I will find out, sooner or later, how accurate your software is. Later
rusty70f100
