mirror flashers
Originally Posted by the4by4freek
You don't. They are LED's. they are built right into the mirror glass.
as for changing them, never done it, so i can;t help you there.
flashers are now fixed
Got back of mirror case off and found that the connectors wern't in as they were disconnected for the M.O.T. over here in the UK,checked bulbs and they were ok so reconnected back up and every thing is now working,Back of mirror case was a pain to get off as there are two plastic clips at the bottom of the mirror with the help of a flat screwdriver it eventually came off plus a broken clip,but all went back together ok.
