surging truck help!!!!!!
Old Dec 18, 2003 | 10:08 AM
ARNO60's Avatar
ARNO60
1992 f-150 5.0,at low rpm truck runs kind like your running out of gas.at high rpm's truck runs fine,just gave it a complete tune up
new fuel filter.have had it on a comp. no codes came up.does anyone have any ideas where i could begin, to find the problem.thanks!!
Old Dec 18, 2003 | 11:23 AM
gasman6674's Avatar
gasman6674
Did You Check Your Fuel Pressure Regulator?
Pull the vac hose off and see if you have raw fuel, If so its toast. Otherwise get a gauge and check your pressure. You might also want to clean/replace your Idle air control vlv/mtr, It could be carboned up.
Good luck
PS I also have a 92 F150 302
Old Dec 18, 2003 | 11:24 AM
LxMan1's Avatar
LxMan1
Also check to make sure that the EGR valve isn't opening too far or not closing completely
Old Dec 19, 2003 | 06:07 PM
madmaxland's Avatar
madmaxland
Also try a couple of bottles of a good brand injector cleaner.
that worked for me.
Old Dec 27, 2003 | 10:07 AM
bob arrington's Avatar
bob arrington
disconnect the vacum line to your EGR valve , if it smoths out ,replace it or just plug the vacum line with a screw depending on where you live , of course,bob
