Dash Lights shorting out ?
Old Dec 18, 2003 | 08:56 AM
isaz's Avatar
isaz
Dash Lights Please Help
This problem is driving me crazy.My dash light don't work once i pull the headlight switch the fuse blows.What can i do
Thanks for your replies...
79 f250 4x4
Old Dec 18, 2003 | 09:33 AM
plowpusher's Avatar
plowpusher
find the short to ground dash lights and tail lights are on the same circuit if you have recently messed with anything start with your taillight wiring or trailer wiring you should have the gang connector for the taillights at the back left rear corner unde the box unplug it then try the dashlights if the fuse stays you know where to look for your short
Old Dec 18, 2003 | 09:49 AM
olfordsnstone's Avatar
olfordsnstone
A spot to look that is often overlooked for a short is, believe it or not, the licence plate light.
Old Dec 18, 2003 | 09:53 AM
isaz's Avatar
isaz
Thanks Guys i will check that.The truck is a flatbed i know where the connecter is i will give it a try.
Old Dec 19, 2003 | 10:00 AM
mathew106's Avatar
mathew106
Mine started this again last nigt. I blew the fuse when I puled the lights on. Another short! Getting old real fast!!!
Old Dec 19, 2003 | 05:50 PM
mathew106's Avatar
mathew106
Mine are fixed, I removed all the old stereo wires. I am installing a new one soon. Looked like a bail of hay when i pulled it all out. That was a mess of wires. Gone now! Lights are not blowing fuses now. Good luck friend
Old Dec 19, 2003 | 06:07 PM
79Indy's Avatar
79Indy
Not to steal this thread, but do your AC/Heater controls light up? Mine don't and I can't get under there to see if it's supposed to have a light or not.
Old Dec 19, 2003 | 06:33 PM
garypettengill's Avatar
garypettengill
79 Indy, There is a single bulb in your heater-A/C control panel. It can be a bear to get at. Someting to do non a weekend when your bored.
Old Dec 19, 2003 | 08:46 PM
79Indy's Avatar
79Indy
Thanks.
Old Dec 19, 2003 | 10:09 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have heard that a high % of auto fires are started by improper audio equipment installations.
Old Dec 20, 2003 | 11:51 AM
mathew106's Avatar
mathew106
you could definetly consider this a fire hazard.
Old Dec 20, 2003 | 10:27 PM
ChargerHemi's Avatar
ChargerHemi
You all know how a '78 dash is divided into three different parts? One for the gas gauge, the second for the speedometer, and the third for the oil and engine temp.? Well, all of my lights work except for the first section (the gas gauge section) and my Reverse lights.
Old Dec 22, 2003 | 09:02 AM
isaz's Avatar
isaz
I fixed hte problem...It was my radio when the previous owner installed it it was wrong i rewired it and everthing lights up now..
Thanks for all the replies you guys have been great..
Old Dec 22, 2003 | 04:50 PM
mathew106's Avatar
mathew106
cool, good job.
Old Dec 23, 2003 | 10:03 AM
meeky moose's Avatar
meeky moose
can i hijack this post now
my 78 has no dash lights at all, but when you hit the dimmer switch and turn on the brights the center light on the speedo comes on..
i haven't been able to figure this one out, its killin me..
