Bronco II Ford Bronco II
88 bronco ll
Old Dec 18, 2003 | 07:53 AM
reidb's Avatar
reidb
88 bronco ll
I am trying to find out the tow capacity for my automatic 1988 bronco ll eddie bauer. Purchased new withe the towing package,
but lost the owners manual. Hoping to tow a boat that weighs around 3700 #'s about 2 miles 3 or 4 times per week during the summer. Thanks for any data or advice.
Bob
Old Dec 18, 2003 | 04:10 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
That sounds like it's to much to me but see what everyone else thinks since its such a short trip.
Old Dec 19, 2003 | 12:27 AM
pat67shorty's Avatar
pat67shorty
It depends on what gear ratio you have in your axels.
Old Dec 19, 2003 | 12:54 PM
87 XLT's Avatar
87 XLT
Best bet is to order an owners manual from www.helminc.com About 15 bucks. Your B-2 might be different, but the owners manual for my 87 Ranger shows that with auto trans/3.45 gears/2.9 liter/trailer brakes & a frame mount weight distributing hitch it can tow 4500 pounds. With 4.10 gears 5,000 pounds. Check with the dealer or order the manual.
Old Dec 20, 2003 | 06:46 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Re: 88 bronco ll
Bob
If you do pull it I would make sure you have GOOOD brakes on the BII and some kind of trailer brakes also!! I hope its a 4x4 so you can pull that much weight up a boat ramp.JM.2W
Old Dec 20, 2003 | 01:34 PM
TheHitMan's Avatar
TheHitMan
if it were me, i would keep an eye out for an inexpensive tow vehicle, like n old ford PU full size. why chance it and burn something up?....just my opinion.
Old Dec 23, 2003 | 09:02 AM
Dave462's Avatar
Dave462
pat67shorty is right, you need to find out what gear ratio you have. Look on the Safety Compliance Certification Label on the driver's door pillar. At the bottom is a set of numbers. The 5th box to the right is labeled axle with 3 characters above the word axle. There will probably be three characters, but you only need the first 2.The codes are as follows.
42 FORD regular 3.45
44 FORD regular 3.73
D4 FORD locking 3.73
D7 FORD locking 4.10
Once you find that, check these for the amount of weight you can tow.
It's broken down in 2 sections dealing with the trailer frontal square footage.
"Trailer frontal area not to exceed base vehicle frontal area".
3.73 0-2,000lbs
4.10 0-2,000lbs
Trailer frontal area, 50 sq. ft. max.
3.73 2,000-4,500lbs
4.10 2,000-4,500lbs
This came from pages 153-156 of the 88 Bronco II Owner's Manual. Hope it helps.
BTW, Ken can I attach anything, such as a .pdf or .jpeg of pages of the owner's manual? If so, how? Thanks.
Dave
_______________________
88 Bronco II, 2.9, Eddie Bauer
Old Dec 23, 2003 | 11:09 AM
Ken00's Avatar
Ken00
If you go to the post reply button, not the reply box at the bottom of the page it will take you to another page that has an attach feature.
