1966 - 1977 Early Broncos
axel questions
Old Dec 17, 2003 | 09:34 PM
68playtruck's Avatar
68playtruck
axel questions
I have a 68 project Bronco with a Dana 30 front axel , With one wheel off the ground the other one will not turn, when I lift both wheels off the ground and turn one the other one turns in the same direction, there is a tag on it that says use limited slip lube only. Also when I spin the drive shaft it takes over 4 1/2 turns to turn the tires one rev, Is that 4.56 to 1. There are some #/s cast into it C-33789 . What do I have? Thanks
Old Dec 18, 2003 | 09:05 AM
spartamouse1's Avatar
spartamouse1
that is a good indication that it is a 4.56 locker. i doubt that any tag # is going to tell you anything. sounds like someone has been into it and changed out the stock stuff for some good stuff. check the ratio in the rear end make sure it is the same.
zapola6
Feb 18, 2016 01:12 PM
OneTon350
Aug 5, 2015 11:19 PM
lmayer460
16
Apr 28, 2015 05:05 PM
Outlaw56
Mar 2, 2015 07:37 PM
underthebridgejim
May 3, 2014 03:28 PM
